investinwaffles
- Apr 26, 2010
So I just scored an amazing deal on some Klipsch Promedia 5.1 speakers ($200!) and they are an amazing upgrade from the promedia 2.1's I had. Absolutely great quality.
Anyway, the original wires that came with them are pretty wimpy looking and definately too short for me to cable manage properly. I have to run the sub "remotely" because it is fucking massive and wont fit anywhere near my desk.
So, im looking for some good budget speaker wire. What should I look for? I like the way this looks (and yes, looks matter to me) but it is expensive. I estimate I will need at least 50ft of it. Anyone know of any cheap all silver wire?
http://cgi.ebay.com/KnuKonceptz-Twi...051?pt=LH_DefaultDomain_0&hash=item5adf9dc793
Should I just get something cheaper like this:
http://www.monoprice.com/products/p...=10239&cs_id=1023901&p_id=2747&seq=1&format=2
Also, I need 3 decent quality long 3.5mm interconnects to go from my Xonar D2X to the sub. Does the quality make a difference? 20ft should be fine:
http://www.monoprice.com/products/p...d=1021802&p_id=5580&seq=1&format=1#largeimage
Thanks in advance. Very psyched to get these hooked up! No idea what to do with the rear speakers though
