Good bandwidth monitoring tool?
Discussion in 'Networking & Security' started by skot, Dec 2, 2004.
  1. skot
    skot Limp Gawd
    137
    Apr 28, 2003
    Hi all,
    I work as a voice and data consultant and we often need to know what the bandwidth utilization of our clients are, however getting this information from the service providers is often difficult and takes awhile.
    My question to all of you is, do you know of any good bandwidth-monitoring tool? What we would like to do is have something installed on a laptop that we could take to our clientÂ’s location and set up that would generate some utilization charts.
    Any suggestions? Thanks!
  2. Darthkim
    Darthkim Limp Gawd
    485
    Dec 17, 2002
    What kind of utilization do you want? Throughput? Protocol distribution?
    This will dictate what you need to get.
    You should be able to get a RMON probe to get most of the info.
    Sniffers also will be able to get that information for you.
    A free one is Ethereal.
    Commercial ones includes Network General Sniffer, Wildpackets Etherpeek, Eeye Iris.
  3. skot
    skot Limp Gawd
    137
    Apr 28, 2003
    I'm looking more for throughput. Thanks for those suggestions. I'll check them out. Are there any free ones that will give throughput? I'm not familiar with RMON, so I'll have to check that out also.
    Thanks again!
  4. DiscardME
    DiscardME [H]Lite
    74
    Aug 12, 2004
    MRTG
    Multi Router Traffic Grapher - it is open source and can be made to monitor anything that allows SNMP or WMI.
    EDIT: Link HERE
  5. draconius
    draconius 2[H]4U
    2,081
    Apr 8, 2002
    What operating systems will you be working with?
    What kind of network access will you have? (IE to the core router, where you can mirror data to another port or switch, or on a switch that you can mirror traffic? or what...)
    I have a few good suggestions but I fear that nonne of them may be applicable in your situation (cacti, nagios come to mind, but the ones already listed are pretty good too )
