CrimandEvil
Dick with a heart of gold
- Oct 22, 2003
Whats the word on the cheaper DFB122512L series version?MC FLMJIG said:He did say the F which is the loudest. You had the E which is medium... no?
Don't doubt the power of the Yate-Loon.Cript said:My s-flexes arrived today to replace my yate loons: 3 Es for my case and 2 Fs for my radiator. And they'll be going back on monday.
The Es are similar to the yate loons in cfm and sound except they have a louder humm when you listen up close; you can't hear it from a few feet away though. However, at 3x the cost this is inexcusable.
The Fs were on my fan controller and exhibited a very loud whine when undervolted down to 5 volts. To make matters worse the whine persists even if I bring them back up. It only goes away when I disconnect and reconnect them. Even though scythe says they're 28db like my yate loons, they're definitely louder.
Overall i'm disappointed, the whole "sony fluid technology" and 150k hour mtbf looked promising.
www.silentpcreview.comMrWizard6600 said:call me a noob, but why is thermaltake noobs? why are their numbers bull?
Geo Fry said:Man what a great thread dtess17!! I keep coming back to it as I've been wanting to get 6 matched quiet 120mm fans... I've learned alot from this thread. It's sad that the S-flex fans have been getting mixed reviews as I was planning on getting them, but then again they are so damn expensive.
Ok so I want to ask a favor of you... I have been using this site as a way to compare 120mm fans to each other as it has sound clips of each fan. After studying it for some time, the GlobalWin fan turned up some very competitive numbers especially for its sound level. It also kept the CPU in the test cooler than any other fan with its low dBa. The reviewer said that he could hear absolutely no motor noise and just air movement.
Well I decided to find this fan and found it here . It's cheap!! It uses a "nanometer ceramic bearing" and is rated for 80,000 hours... For its price and performance it seems like a much better deal than the S-flex E series but idk. So I ordered 2 and will let you all know how I like it... Sadly I only have a few 120mm fans to compare it too so maybe dtess you could get 1 and compare it to your S-flex E and any other you have .
IMO this fan seems quite promising for its price
dtess17 said:i am going to order some of the Artic Cooling ACF12 to see how they compair to the s flex
the only problem i see with them is the 38mm thickness...might make use in some places more difficult.
i'll keep everyone updated.
PsycoGeek said:Any update on the Arctic Cooling fanes yet?
dtess17 said:should be here within a day or two, i got em off ebay and the seller used snail mail.
but i will have something on those soon too.
PsycoGeek said:Fantastic... I am looking foreward to your opinions on them. One question I have though, which way is the air flow through the fan? Towards or away from the mounting side?
Thanatos. said:Dont go with SilenX they lie about thair CFM & dBA.
dtess17 said:you know what is real funny though, i nit pick about little things in my computer, and i am always looking for something to make it more quiet...but if it's not on at night, i have trouble sleeping...the average person might not even hear the machine, but for some reason i need it now.
vibe said:I wanted to thank y'all for this thread...
My darn power supply is not even two months old and I've detected a rattle from the 120mm fan already. They just had to cut corners with a sleeved unit. So time for replacement already, sigh.
dtess17 said:depends on each case.
it will improve airflow, but does not always cut noise as much as you might think it would.
a good pair of wire cutters, or steel snips should take care of it.
just make sure you leave some to supprt the fan, start from the middle and work out.
Gatticus said:I read on some website once that sleeved fans are actually quieter than bearing fans but bearing fans last longer. I don't know if that's true or not, I doubt it because my Seasonic PSU uses double ball bearing fan and it is very quiet.
PsycoGeek said:I always remove the case fan grilles. Have been doing that for about 7 years now.
Get Wiss (from home depot ) curved tin snips. They make great circles.Gatticus said:What tools do you use to cut out the grill? The tin snips mentioned will work but that sounds messy and will leave jagged edges. I want a a nice clean cut and smooth edges. I have a friend with a few power tools and he may have what I need.
markkleb said:Get Wiss (from home depot ) curved tin snips. They make great circles.
I am sorry if someone already posted these fans but I really like the AC cooling 8's.The sides are open for better air flow and they have a rubber suspension to keep down noise and they are only 4 for $20 (for 80's)
http://www.coolerguys.com/840556026105.html
here is the 120's
http://www.coolerguys.com/840556026129.html
But for really quiet I use these (amazing)
http://www.subzeropcs.com/silenx_120_x_38mm_14db_pro_fan.html
Geo Fry said:Well I decided to find this fan and found it here . It's cheap!! It uses a "nanometer ceramic bearing" and is rated for 80,000 hours... For its price and performance it seems like a much better deal than the S-flex E series but idk. So I ordered 2 and will let you all know how I like it... Sadly I only have a few 120mm fans to compare it too so maybe dtess you could get 1 and compare it to your S-flex E and any other you have .
Gatticus said:Well, I don't trust these numbers either.
Cooler Master LED - (22dba/43cfm)
I have two of these fans in my case and they were no quieter than the Antec 120mm fans I already had. I had to put volt mods on them to make them quiet. They were damn cheap though and a good buy for the money, volt mod them though if you want quiet.
markkleb said:But for really quiet I use these (amazing)
takeabao said:
I hope you like paying $20 bucks per fan for junk.
PsycoGeek said:No, I wouldn't dissasemble a case to do it either. Especially if it was your only PC. It is a PITA for sure, but if you have a new case worth the effort. My cases have always been quieter because of it, although a bit of a hazard to any cats waving their tails around where they shouldn't be...
If you do it, you have to be sure to make the hole the same size the fan is. Keep in mind that a fan housing is actually tapered hear it's outer edges, and narrower in the center where the blades are. If you don't get the hole to match the fan housing exactly, you are still allowing a lip of sheet metal to overlap the fan, and it will produce turbulence, and noise.
