newls1
- Sep 8, 2003
Good morning people! I'm currently using a Xeon E5 2658 V3 ES processor @ 2.3ghz x12cores and really enjoy the threading ability of this CHEAP CPU! Im entertaining the idea of going with a *DUAL CPU* 2011-3 setup for the reason of "JUST CAUSE" but certainly cant afford a 350$+ Motherboard for this project. What im needing in a motherboard and what I need your advice on is motherboard choice???? Here are my *NEEDS* for a motherboard for this project
1. will support 2 E5 2658 v3 ES cpus @ 2.3ghz
2. will support regular ddr4 ram
3. full pcie 3.0 x16 slot for a single gpu
4. either a m.2 pcie x4 3.0 slot OR pcie 3.0 x4 slot on motherboard so i can attach my m.2 on a pcie riser card.
think thats it...... Please help me search for this board. I have never built a dual cpu setup and think it would be alot of fun. I appreciate any feedback you can help me with!
