Mister E
- Sep 14, 2004
As the final upgrade to the sig rig I'm going to update the ram to 16GB. I want to buy a new set of 2x8GB sticks since my CPU cooler won't let me add another matching set to occupy the other two available ram slots. One slot is completely blocked unless I get a really low profile ram. So I'll just grab two new sticks and sell the existing ones. Here are my questions.
1. Will getting 2400 speed (or maybe 2133) ram help me at all? I asked this question a long time ago and the answer was that 1600 was the fastest useful speed. Anything above that on my platform would be a waste. Is this still the case today? Gaming at 4K is the most demanding thing I do.
2. How important are ram timings on fast memory? If I spend the money (which I don't mind doing) on the faster ram, should I get the lowest timings even if it's more expensive? Or just go with the run of the mill ram?
3. Heat spreaders? I like the look and want to keep the blue and black color scheme I have. Are they anything but flash on today's ram or do they serve a purpose? Googling says yes and no.
4. Should I just say screw it and stick with the 8GB I have for Windows 10 Home and 4K gaming?
Thanks for any input you guys have.
