I've got a P67 mobo and i5 3350p cpu @ 3.1 - 3.3ghz
Looking at 9th generation Z97 with maybe i5-4690K hoping to get to 4ghz
is it worth the $300 ?
Dunno.
If you keep it in its box, you wont notice unless you keep the box open.
Is it possible for me to get that 400mhz overclock without having to mess with increasing the voltage & stability testing? When i look in my bios the highest multiplier i can select is 29.
Yup, it's adjusting the max turbo boost, not a multiplier adjustment. Multiplier is only unlocked on the K processors.
See here where they overclocked a Core i5 2400 by 400 MHz:
http://www.xbitlabs.com/articles/cpu/display/core-i5-2500-2400-2300_11.html
All desktop Core i5 and i7s (Sandy and Ivy) can do this on an overclocking motherboard. Since all turbo-boost parts are validated with a predefined voltage curve in the factory, they don't need any voltage tweaks.
Interesting, so basically it allows all four cores to run even at maximum multiplier which is meant for one core?
I vaguely remember seeing "turbo" in the bios but not sure if it was accessible for me.
Right now running with a simple 105 bclk which is the only overclock you can do with the old ivy i5
3350p has a max multiplier of 33x meant for when only one core is in use, otherwise 31x
it's a very low end quad-core but runs cooler because there isn't any graphics circuitry
