Comixbooks
- Jun 7, 2008
I read something the jump from 1080P to 1440P is pretty significant but going from 1440P to 4k you can't notice as much.
There is another way to improve 1080p so the difference from 1440p isnt as much AND you get to turn off AA.
Use 1440p DSR.
It looks a bit more detailed and gives around the same quality as 4x MSAA. Turn on FXAA if you get any crawlies, this has almost no performance hit.
This gives a lot higher framerate than 1440p with AA.
I didnt make that claim.
Went from 1050p straight to a good IPS 4k monitor. Text seems better, but I would prefer the 16:10 aspect ratio.
There are too many variables to this. If you've got a 24" 1080P monitor and you end up on a 27" 1440P monitor you'll notice quite the difference. Stepping up to 4K is a huge difference from either of those at virtually any size. But panel quality, viewing angles, response times etc. all factor into the overall experience.
At 48" I'm good with 16:9. At 27" or 30" fuck yeah, 16:10 all the way.
27" 16:9 is ok, but 24" 16:9 looks like a letterbox.
