Any such thing?
Wait for the u3014. It isn't glossy, but the AG is a thin anti reflective coating - it will be much, much, muchmuch better than the thick matte on the u3011.
The u2713HM and H use it, and it isn't even noticeable. Its great.
Nobody has had the balls to remove the AG on a 30"?
What's wrong with the 27"?
Nothing, I just wanted a bigger glossy monitor, haha
Why would anyone want a glossy screen?
The only thing it has is glare..
Because thick matte coatings can be annoying in dimly lit environments, to the point that it causes black text on white backgrounds to be less sharp.
This shouldn't be an issue with the upcoming u3014 as mentioned - it will be using the same excellent light anti reflective coating as the 2713H/HM. Trust me, you won't even notice that coating, it is quite good.
Image clarity and color vibrancy. Glare is easy to control if you plan your room accordingly.
I'll take a few reflections on dark backgrounds over dirty, grainy antiglare on light colored backgrounds.
Well, that's fine, but on my 3007WFP-HC, I never notice that it is unclear, or not vibrant enough.. or anything like that.
K.
http://www.overclockers.ru/images/lab/2012/12/11/1/39_kristaleffect_big.jpg
Both of your displays use the same coating as the U2711/HPZR2740W, as do most of the other IPS in these images which shows the effect of different coatings on pixels. Only the S234/S2440L and 27Q LED-P are glossy, the rest are matte, notice how much clearer many of the other panels look.
Maybe I should sell my 3007 for a 3014?
YES! Have 2707wfp dell just sitting here not being used soooo thought I would give it a try. Didn't even have a clue if it had AG just some kind of AG. Put 2 layers of paper towels wet left for 3 1/2 - 4 hours. And it came off perfect! Made sure was all dry. I didn't take it all a part like he did in that link posted.
MAN AWESOME. Love gloss. BRIGHT now and clear. THANKS guys..
