...using 2 AFB1212VHE's as bread...
I saw an immediate 5c+ drop in temps...at idle coretemp shows 2 cores in the teens (18c)...under load peak temps never crease over 48c under prolonged 100% load with intelburntest...
this is Q6600 (1.325vid) @ 3.3ghz 1.41v idle, VTT 1.38, NB 1.37...all others stock volts
i could probably 7v these fans and really cut the noise without even being much worse off than 1 fan...prolly the same or just a nip better cooling...
one could also do this with a pair of silent or near silent fans and likely see a nice improvement...
fans are mounted with 8-32 threaded rod thru the fins of the Xig and nuts on both ends...like i said...basically a Xigmatek sandwich...
thus ends today's experimentation...back to your regularly scheduled [H]
