d50man
- Jan 22, 2002
I have an 3570k CM HYPER 212 1stick 4gb ddr3 AX850 psu on right now it goes post code db, then restarts, then 15, 36, 4F, the goes really fast 96.... then reboots.
Can I buy a usb bios programmer and soic8 clip to fix the bios (and learning the required software) or should I just RMA the gigabyte service (not under warranty) AND WAIT 2 WEEKS
Both bios are hosed at this point but all they should need is a flash.
LMK what you guys think I've had no problems until now reducing voltages and speeds for air cooling instead of water.
