Ocellaris
- Jan 1, 2008
I have a Gigabyte Z170 Gaming 3 board which I've been pretty happy with since Skylake launch. I had a early issue with my RAM running XMP profiles however they fixed that with a quick BIOS update. It ran my i5 6500 perfectly fine. When the Kaby Lake CPUs launched, I decided to upgrade to an i7 7700K. Gigabyte added support for Kaby lake CPUs many weeks ago so I figured everything would work fine with their F20 BIOS.
Once I installed the 7700K I notice it was running real hot in stress tests. Like just under 90C hot using a H60 cooler. I tried to make the H60 work better with little success, the CPU was going over 80C running Prime 95 with AVX. I ended up replacing the cooler and every single fan in the PC with Noctua gear. This bought my P95 temps barely under 80C most of the time and Real Bench temps were right at 70C. Prime 95 temps were over 80C if the GPU was I use. Also I removed all of the dust collecting mesh so the PC was as open as possible. I noticed that P95 was causing the CPU to draw 130W of power, yikes!
Overall I was really frustrated and finally started looking into which delid block to buy. Yesterday I noticed a new F21 BIOS update with the following notes:
Old F20 BIOS
Real Bench: 70C max
Prime 95 w/AVX: 80C+
Max power draw: 130W
New F21 BIOS
Real Bench: 60C max (1 hour)
Prime 95 w/AVX: 68C max (2 hour run with small FFTs)
Max power draw: 100W
I am pretty impressed Gigabyte screwed up this bad with initial Kaby Lake support. I pity anyone who was trying to overclock with a GB Z170 + Kaby board when the board was just dumping way too much voltage into the chip.
Cliff notes: If you are running Kaby Lake on a Z170 board, check for BIOS updates
I updated to this BIOS and my temps are massively down. The chip is running less voltage and now maxes out around 1.176V.
- V core Voltage adjust
Old F20 BIOS
Real Bench: 70C max
New F21 BIOS
