Gigabyte X99p-SLI vs UD4, which one to keep?
D-EJ915
SLI one has thunderbolt on it but fewer USB ports so that would probably be the deciding factor for me neither mentions having an oc socket.
dexvx
Are the VRM's on both the same? If they are, I would lean towards the X99P-SLI.
D-EJ915
Tweaktown's reviews show they both use the same powir stage 3556 50 amp x 6. It says they have different controllers but I don't think that would make that much of a difference.
Their review does say the P-SLI board has OC Socket enable/disable so I'd go for that one.
