Gigabyte X570 Aorus Master won't power on - (temporary) solution
A "Thousand Thanx" ColdSteel....I finished my work day. Uncovered my pride and joy...hit the power button...and {nothing}.....after crying for awhile, and searching "X570 Auros Master wont boot" - this was the first thread that came up. 30min later, was back up and running after removing the 2080ti and resetting the CMOS battery. You are a GOD among us Mortals! Thank you!
USAF46270
Glad our thread helped! What BIOS revision are you on?
luckyguy40
After almost a year it has happened again to me. Third time ever, b550-aorus pro+3900x, bios f10a, same pattern: gaming few hours on win10 which is very uncommon for me, comeback to linux and dead next morning. (battery off 15min and okay again)
There are newer bios available, thinking if I should update or just enjoy peace for another year :>
Mizzer
On my x570 Master I jumped from F11 to F33 (I think). I never encountered the power issue. I’d say try the latest non-beta bios.
charpour
Anyone here knows which BIOS is needed for SAM support on 3000 CPU ? If it exists at all that is!
Bobrolak
Thanks for the news about SAM for 3000, I somehow missed it.
Master on F32 Bios here and 3900x - I can see it under: Settings -> IO Ports -> Re-Size BAR support
Sidenote: it requires PCIE 4.0 graphics card, so only newest AMD/Nvidia gen
Lotus8720
Hello all,
First I would like to say thanks for all the above information. I woke this morning and my system appears to have some of the same issues above. I left my system on all night (I would normally power down) and when I came into my office to start work, I noticed my RGB lights on, but my screen saver not working. I pressed the spacebar to wake my computer up and nothing. I did a hard power reset and I could hear my power supply click. I have another power supply that I tried with the same results. I started unplugging cards to troubleshoot. The only way I could get my system to boot was to leave one of the 8pin CPU power connections on the motherboard unplugged. My CMOS battery is hidden and I would have to drain my loop and take my system most of the away apart to access it. I've opened a case with Gigabyte, but I'm sure it will be a dead end. Can some one please point me in right direction to fixing this issue? Again I have my system up and running now with only one 8pin power connection. My system has been running fine for the past 11 months with no issues until today.
System Specs
Gigabyte TRX40 AORUS XTREME Rev 1.0
Threadripper 3960x
Bios F4p
128GB Memory
RTX 5000 GPU
EVGA 1300 G2 PS (using my Corsair AX1500i now)
Windows 10 64Bit
Running since 5/20 just fine
Thanks
Thanks and sorry Cold_Steel!
cold_steel
Hello all,
System Specs
Threadripper 3960x
Bios F4p
128GB Memory
RTX 5000 GPU
Windows 10 64Bit
Thanks
This sounds like a bit of a different issue, and this is a different motherboard; definitely suggest starting a new thread for your issue to have more eyes on it rather than buried in this thread.
Mizzer
Hello all,
System Specs
Threadripper 3960x
Bios F4p
128GB Memory
RTX 5000 GPU
Windows 10 64Bit
Thanks
Can you get to a “reset bios” jumper? Those are typically on the edge of boards.
Lotus8720
Yes, I was going to do that after writing down all of my settings information. I tried again last night to plug both 8pin connectors to my motherboard and nothing. It still works with only one 8pin connection. It was been working fine for 11months and from nowhere this.
cold_steel
This absolutely sounds like a different problem than what this thread is addressing unfortunately (or, fortunately :))
Mizzer
I feel for you, man. I had a system that would periodically freeze in games. Nothing but a hard reset would bring it back. Ran all kinds of diagnostics and stress tests. Everything checked out. Switched out PSU, RAM, GPU, hdds... nothing. So I parted it out and sold everything. Each part worked as expected for every buyer. Still a mystery to this day (happened about 10 years ago).
Good luck!
lopoetve
Good luck!
Had that with TWO different polaris cards. Both worked fine for everyone else, did weird stuff for me. Replaced with a 5700xt, problem gone... o_O
therealjustin
Guys, I want to use this board for a new build but I'm nervous... :cautious:
I could settle for the Elite but that doesn't seem more reliable.
DeaconFrost
I just finished an upgrade in my primary system to an x570 Elite. So far, only some USB quirkiness that may have been due to a bad flash drive. I run my systems for a day or so with a Linux Live USB flash to test. I'll be doing the Windows 10 install in the next few days.
lopoetve
get the latest bios for the USB disconnect issues. I have that board and encountered that - used an externally powered USB3.1 card to solve it, and haven't bothered switching back to the internal USB ports yet.
DeaconFrost
I have F32 loaded. I'm always hesitant to try a beta BIOS unless I'm having major issues (and those are claimed to be resolved in the beta BIOS).
Baipass
Had this issue and fixed it by removing the CMOS battery. Thanks for thread. On a F22 BIOS currently will be looking to upgrade soon. Hopefully won't see this again.
vegeta535
Anyone having issues on 33j with realtek HD audio?
Like what? I notice static starts to come out my speakers after a while. Turning them on and off gets rid of it. I am using optical out to a DAC. It did it also using USB to my DAC.
BitFlip
Literally there was no audio, nothing even though the driver was reported as working ok, I tried the uninstall driver with the delete software option ticked, but it would just reboot reinstall a driver and again no sound.
I have just fixed it anyway using DDU to remove Realtek HD Audio (WIP) driver then rebooted, reinstalled the driver from gigabyte, and it sprung back to life.
I really do not like Realtek so I think I'm going to get a Sound Blaster Audigy had one mid 2k's loved it.
Oh and on topic still no dead mobo :)
vegeta535
Audio is working fine outside what I posted above. I know it is a dumb suggestion but do you have the right output selected in windows? Randomly sometimes it switches to my CX speakers and I get no audio even tho I have them muted on the TV itself.
BitFlip
Yeah 1st place I went to as I sometimes get the same issue with it selecting my LG monitor as the output device lol!
Dunno what happened but its sorted now.
Baipass
Funny enough I also had an issue with the driver... disabling, uninstalling, and reinstalling the latest one didn't fix it. I downloaded the Driver booster free version selected the Realtek driver and used their "fix" troubleshooting solution. The Driver booster was able to fix it thankfully! This is after I updated the BIOS to 33j
