- May 18, 1997
Gigabyte X399 Aorus Xtreme Unboxing
Video rendering now.
XMP is actually intel's spec, AMP is amd's. so yes XMP does not always work right with amd so manually setting the timings to the XMP values will usually help. a little extra voltage can also help stabilize it too.Darnit:
https://www.amazon.com/Corsair-2x16...ywd?pageNumber=1&filterByKeyword=threadripper
Some guy also had stability issues with this 2x16gb ram, with another board.
Does anyone run their DDR4 RAM without using XMP but rather manual timings and voltages, e.g. maybe use 1.4v? I've read that sometimes helps stability. This is the cheapest 3200 Mhz RAM out there, and even 2933 G.Skill is way more expensive, at least in the 16gb module variety.
