Gigabyte GTX 1080ti gaming overclock dieing when gaming.
Discussion in 'nVidia Flavor' started by DavidD, Apr 12, 2019.
  1. DavidD
    DavidD n00b
    10
    Oct 21, 2018
    When playing Diablo3 or Guild Wars2 if the action gets to intense, to many items rendered my card just dies no blue screen direct to reboot. What setting should I change?
  2. Araxie
    Araxie [H]ardness Supreme
    6,380
    Feb 11, 2013
    Your PSU..
    Big[H] likes this.
  3. Big[H]
    Big[H] Gawd
    774
    Aug 23, 2001
    I had a similar issue. When I got the same card, it would either throw weird nonsense BSODs or freeze outright. Changed my PSU and it fixed it like Araxie said above.
  4. thecold
    thecold Limp Gawd
    304
    Nov 12, 2017
    like the other 2 said, likely psu.
  5. pippenainteasy
    pippenainteasy Gawd
    609
    May 20, 2016
    And in the meantime you should probably cap your fps. I know Diablo 3 has a built in frame limited but RTSS is a good program to use as well.
  6. DavidD
    DavidD n00b
    10
    Oct 21, 2018
    My PSU is an Antec Truepower Quatro 1000. Normally I would say that should cover it but it is quite old, and it did live through a lightning strike before I upgraded the the MoB and GPU... I will look into a new PSU, any suggestions?
  7. waterbucket
    waterbucket n00b
    30
    Feb 10, 2018
    I’m using a Corsair HX 850 with an 8700k at 4.8ghz and a Strix 1080 Ti OC. Seems to get the job done.
