Recently we have had quite a few power fluctuations in my area, and I decided to install a UPS in my server rack. I had an old Eaton Powerware 5125-1500 with 1 EBM that I replaced the batteries on, and yesterday I decided to install. Funny enough, about 1 hour before I went down to shut everything down the power cycled on in the house. Everything seemed to come up and be in working order, and I had no issues shutting down both my ESXi host, and my Unraid box (the GIGABYTE GA-Z68MA-D2H-B3 is housed in it). I pulled the old rack mounted 1U PDU's out, installed a new 0U Blackbox PDU, and installed the UPS with the EBM. ESXi host powered up fine, Unraid box just flashes LED's on the front for a split second and then nothing. The fans spin up, for a second, then nothing. I have to switch the PSU off/on to even replicate the symptoms.
Unraid Box Setup
Norco 4020
Intel Celeron G530
16GB Corsair DDR3
Antec ECO 620
I have been through quite a few troubleshooting steps.
1. Tested PSU with cheap eBay tester - passed.
2. Swapped a new Rosewill 620W PSU - no difference
3. Reseated Ram - no difference
4. Swapped RAM for a single stick of Avexir (sp?) - no difference
5. Pulled the front panel header wires off, tried a jumper wire to initiate post - no difference
6. Swapped a spare AMD AM3 mobo/cpu in and booted up successfully.
Thoughts.
1. The UPS I have claims pure sine wave, and both PSU have active PFC. The ESX host is a Dell C1100 so I cannot confirm if its PSU is or is not. I dont have a ton of experience with UPS's, and the model I am using is older. I am hoping I do not have an incompatibility and it fried the Unraid box.
2. I tried the Unraid box on both wall power and the UPS and it had the same issues/symptoms.
3. I am leaning towards a new supermicro mobo/CPU combo, but what I don't want is to damage those if anyone things it is a UPS issue.
Any thoughts?
Unraid Box Setup
Norco 4020
Intel Celeron G530
16GB Corsair DDR3
Antec ECO 620
Thoughts.
Any thoughts?
