My rig is in my sig:
I have some stupid questions.......
I bought 4GB Mushkin XP PC2-6400 EPP memory and when I put it in an pressed the power button, the computer comes on for about 2 seconds, shuts off then turns on and boots....weird.
When I tried booting to windows, I kept getting BSODs. Now, this ram has printed on it 2.0v. Is the default setting for ram in the bios 1.8v? If so, if I use the DDR Overvolt bios and d seand set it to 0.20+ v give me 2.0v? According to Everest my 2.5v setting is 2.0v and according to Easytune 5 it is set to 2.0v.
When I use CPU-Z it says my memory frequency is set to 533Mhz and my FSB:RAM is set to 1:2 with timings of 5-5-5-15. Isn't it supposed to be set to 4-4-3-10 @ 400MHz? How do i set it to do that? I don't want to kill my ram.
Thanks
Thanks
