Gigabyte GA-K8NS Ultra 939 Sensors Help?
Discussion in 'AMD MoBos' started by branana, Nov 27, 2006.
  1. branana
    branana Limp Gawd
    269
    Apr 10, 2004
    I have the following setup:
    Newcastle 3500+
    6800GT AGP
    Gigabyte K8NS Ultra 939 motherboard
    and some other random parts in there.
    Anyways, I'm going to be picking up an Opteron 170 this week, I thought i'd look up the temperature situation I have in there. (Never bothered before). Here's a screenshot of Speedfan:
    [​IMG]
    I'm having a hard time identifying which temperature is which.....
    I have a Lian-Li PC65B case:
    [​IMG]
    There are fans all over the place.
    I'm using this Zalman CNPS7000B-cu heatsink:
    [​IMG]
    And I'm pretty sure I applied the Arctic silver just the right amount. Not the first, second, or 10th computer i built now.....
    I'm wondering wtf is @ 59 degrees??? Is that the core diode reading? What is "remote". Which of those temperatures is my case temp, cpu temp? The only ones i can sort of tell are the hard drive temperatures.
    Please enlighten me. Any help appreciated.
    I know it's not the video card temp, cuz that's at:
    [​IMG]
  2. wesleys_dad
    wesleys_dad [H]ard|Gawd
    1,271
    Jun 21, 2005
    on my rig the temp 1 is the cpu temp.
    temp 2 is the mobo temp
    temp 3 is nothing,27c
    i also have a second temp 1 which looks like the nf4 chipset temp at around 38-40c
    my board is an asus a8n-e
    see if this helps.i run motherboard monitor and i can compare the temps and see if they match up.you may want to run mbm and see if it works on your board.
