Alright so I am working on a new build with a gigabyte ex58 ud4p and a hd 4890.
When I go to power the system on, 50% pf the time, all I get is one beep and then the machine turns off.
Maybe 40% of the time I get the post code for a grahpics/monitor error
and 10% of the time the machine just kind of beeps unintelligably with something that doesn't match an error code then turns off.
By "turning on" I mean the fans and lights go on.
I tried swapping in a different, working gpu (it's running in another machine right now), I tried reseating and trying each of the ram sticks individually.
I've checked connections on the mobo.
Any suggestions on what I should do?
Thanks.
Thanks.
