Digital Viper-X-
- Dec 9, 2000
The memory pads seem to suck on everything stock. FE included.
Oh yeah, that makes sense. I always go for super, super deep cases.Problem for alot of folks is the 30 series cards are already almost comically long, the powerlink puts it off the end of the board instead of behind it.
Even in the example above you couldnt fit a powerlink in that sliver of space, but the 180 degree connectors fit.
Well the front side of the card has the cooler so my view is the hot vram is on the backside of the card. Anyways the EVGA pads were better than the ones I installed. It is more likely the original was 1.5mm pads while I put thicker ones, 2mm on, which is my thought or the rating of the pads is incorrect. Once I get the CPU water cooler, I will install the heatsinks on the backside for the vram and that will tell clearly if I need to do the front side of the card.^ That pad mod to the 3090 is a little perplexing, no offense. Doing only the back VRAM modules on a 3090, I'm not surprised TJ temp actually went up.
The backplate is not a heatsink, and most of the benefit from these 2mm pad swaps comes from doing the front VRAM modules since EVGA stock pads don't transfer heat as well as the thermalright pads.
I haven't needed to do a 3090 yet, but if that GPU were mine I would've swapped only front 2mm pads and tested, and then maybe done back modules with low expectations, and then only if I also had actual airflow across the backplate for it to even matter.
3090 is the wrong card for that particular case and CPU cooler setup while also trying to do memory OC intensive mining, and new pads can't perform miracles.
Don't bother with backplate side. Just the VRAM pads 2.0mm, and a non-conductive paste for the core (Noctua NH-14). Watercooling not needed.I was on the fence about water-coo=ing or buying the generic thermal pads, but Im buying them today.
Do I need to put pads on the backplate side as well?
Also what a good thermal paste to use?
Definitely something to keep in mind. Some cards are insanely easy to take apart, only have 8 screws that are easy to get to. Others can be a true pita.Don't bother with backplate side. Just the VRAM pads 2.0mm, and a non-conductive paste for the core (Noctua NH-14). Watercooling not needed.
I now have two of those Gigabyte 3080 Eagles and they're both fantastic after re-pad. Theyre also way easier to take apart and put back together than other AIB brands of 3080s that require a lot of additional steps (TUF 3080 for example is a nightmare to take apart).
Pads ordered earlier, paste now.Don't bother with backplate side. Just the VRAM pads 2.0mm, and a non-conductive paste for the core (Noctua NH-14). Watercooling not needed.
Only can make the gpu HS so big. ESP as more and more want to use SFF cases.After working with several more of these Gigabyte cards including the flagship Aorus 3090 Xtremes - that have the same white pads on the VRAM as the basemodel 3080s - it's become obvious why Gigabyte chose these pads: it's not because it was some oversight on their part to use "crap" pads. They were specifically chosen to limit the heat being dumped into block from the VRAM in order to preserve the core's thermal headroom. Particularly on a 3090, the amount of extra heat from VRAM that the core has to contend with if denser thermal pads are used can be significant (6-10C or more).
Gotta remember these GPUs were not designed for mining where VRAM OCd to high hell is the primary concern and the core is secondary. For most GPU applications, the core performance and therefore temp was the primary consideration.
Other AIBs have chosen slightly denser pads for their VRAM. Each company struck their own balance based on various factors. It is what it is.
At least we have the option to tilt the thermal balance one way or the other by changing the pads ourselves, and it only takes a few minutes.
how much material did you have to buy? the $17 package seems like so little, do you need 2 of those or just 1?I started mining on my Gigabyte 3080 Aorus Master in my off hours recently and noticed the fans would hit 100% almost instantly with memory temps at 110C. Gaming thermals were actually decent, 70% fan speed and ~65C on the core. I checked around and it seemed to be a common complaint with all versions of Gigabyte cards with most people adding 3mm thermal pads to the back (there are non on the back of the memory) and 1.5-2mm pads on the front.
I ordered some Thermalright 12.8W/mK pads off Amazon and did the swap tonight and it dropped temps on the memory by 22C!
Stock - 100% Fan, 110C Memory
New Pads - 70% Fan, 88C Memory
I can't believe how much of a difference it makes. It does raise the core temp though as now heat is actually getting through to the heatsink from the memory. I strongly recommend replacing and adding pads if you mine on a Gigabyte card, although check with local RMA policies before doing so.
Is the back necessary?I ended up using one pack of 3mm for the back and 1 pack of 1.5 mm for the front. 2mm on the front is probably safer though. You should have just enough if you don't make any mistakes.
Ill judge by the front pads difference then.Not really, some people said adding to the back with stock pads on front only dropped memory 1-2 degrees.
Yeah its night and day difference.wow what a difference this makes. dropped 40c on the vram for me and the fans went from 100% to like 45%.
There aren't any fans to reconnect.Did you reconnect the fans?
No. You'd be fine if you weren't mining.
Mining is just a convenient way to offset the cost of the card for a lot of people.
I half way figured out my problem...I have a Aorus waterforce 3080 and the temps have been creeping up on the GPU itself for the past few weeks. It was up to +20C over the other card on the same cooling system....another gigabyte that I had re-padded and pasted from the start because it was so incredibly sucky. It works really well now. Anyway time to repaste I figured. So yesterday I tore it down and re-padded and repasted. Interesting on my card, all the pads look to be 0.5mm pads. I added pads to the back while I was at it, buttoned it up and fired it up again.
Now the GPU is still running hot and the RAM temps just sky rocket and are throttling. I have no clue what is going on. I am pretty sure I'm making contact everywhere. I can read nvidia in the thermal paste on the waterblock when I disassemble, so I knw I'm squished tight there. And I can see imprints on the pads. I truly am baffled.
What pads would you recommend for an asus tuf 3090? It runs completely reasonable numbers while gaming and during daily use, but during the summer, I started noticing the mem temps approaching 105-110c after long mining sessions. I'm just looking to reign it back so that I don't have to max out my fans while mining just to keep the memory temps from cascading into hot lava.
That's wayyyyyy too much imo.I did the back pads on my friend's air cooled 3090FE using Fuji Poly pads. Temps did go down, but when he played this game "Control" (it really takes advantage of the card), he hit 92C. He does have a Vornado fan blowing on the side of his PC, side cover is obviously removed.
I also water blocked his 1st 3090FE using EK's water block using 1.5mm, 1mm, and 0.5mm Fujupoly pads on the front and back. Well, needless to say, the temps were amazing. He bought like $300+ of Fujipoly pads though. But if you can afford two 3090Fe's, what's $300?
You sure you can sustain 136 mh/s with no rejected shares/overheating? haven't heard of anyone going above like 125-128 mh/s for 3090s lol.This may help:
https://www.reddit.com/r/nvidia/comments/mmquqs/asus_tuf_3090_thermal_pad_replacement_and_deshroud/
I will be doing my Gigabyte 3080Ti Eagle this week, hopefully on Wednesday when the 2mm pads come in. I have an assortment already from 3mm down except for the 2mm which I need for the VRAM. I may or may not do the VRMs, depending upon if I tear them up or not and condition.
I use the different thickness sizes of these:
https://www.amazon.com/dp/B08Y6V5JK6?psc=1&ref=ppx_yo2_dt_b_product_details
On my EVGA 3090 XC3, it took a lot, Hybrid cooler which has all new pads + backside VRAM using 3mm pads from above + Heat sinks on backplate + fan -> 110C throttling at less than 100mh/s to low 90s at 113mh/s (I can go up to 136mh/s, really stressing card/power) and still below 100c).
I have a 3080 that does like 107 under water and a 3090 at126, but admittedly haven't pushed the 3090 up like I did the 3080. Never seemed to have the time...the 3090 has a full cover waterblock. I bet I can squeeze more performance out of it especially now....my water is always cool these days.You sure you can sustain 136 mh/s with no rejected shares/overheating? haven't heard of anyone going above like 125-128 mh/s for 3090s lol.
Just retried and got up to 124mh/s, not 136mh/s pushing it further caused a crash. Either I was mistaken or something changed, looks more like I did not remember right.You sure you can sustain 136 mh/s with no rejected shares/overheating? haven't heard of anyone going above like 125-128 mh/s for 3090s lol.
I have some of that stuff. it works well...and i don't remember being $190 either. I got a little bottle, i want to say it was like $24.https://www.digikey.com/en/products/detail/t-global-technology/TG-PP10-1000/6204865
$190 1000g tub of thermal putty rated for 10W/m-k... in stock (5 left), the putty are reusable also since you can just squish them to size and reapply.
EVGA charges $9.99 for a 8g tube for reference https://www.evga.com/products/product.aspx?pn=M047-10-000003
That stuff is a real PITA to clean off the VRMs/inductors. I'm going try to avoid using it if possible.https://www.digikey.com/en/products/detail/t-global-technology/TG-PP10-1000/6204865
