I finally bought a Netgear 8-port gigabit switch which supports Jumbo Frames. However, I will only have 3 PC's out of 10 on gigabit. I just need gigabit speeds for my fileserver and 2 main PC's.
I heard if you are mixing a network with 100/1000Mbit's then Jumbo Frames causes more headache then good. Is this true?
I was always under the impression that CAT6 just had better shielding, so it had less interference and a longer range then CAT5e. Also, that CAT6 future proofs you a little better since it can support up to 2000Mbit. I currently have CAT5e cabling and the 3 PC's on gigabit are 14 feet from each other in the basement, which run along the wall under the carpet. Someone told me I should upgrade to CAT6 because I will see ~20% improvement in throughput. Is this true? If it is then I don't mind replacing all cables to CAT6... but it would be disappointing to see no improvements in transfer rates.
Thanks!
Thanks!
