I'm having problems with Ghost (the 'enterprise' edition, v8.2). It seems to be mangling my NTFS partitions.
My original drive has 4 partitions -
1) NTFS, 23GB
2) Linux Swap, 1GB
3) Linux EXT2, 5GB
4) FAT32 local storage - the rest
Windows XP SP2 is installed on the NTFS partition. I'm using GRUB as my bootloader.
I'm using the Ghostcast Server to create the image & then send it back out to the clones (after running sysprep). After the image comes back up, GRUB doesn't work but this is an easy fix. The problem is that Windows will not boot. It just sits there.
I've made sure that partition 1 is active & used a win98 bootdisk to fdisk /mbr. It still says "Missing Operating System".
After fixing GRUB, Linux boots just fine. I can mount the NTFS partition & it looks like all my files are there - including boot.ini and ntldr.
Some of the machines have different HDDs (different brand of 40GB) but even the ones with identical drives have the problem.
I've used the exact same procedure to image 2 other labs (30 machines) with different hardware. Is there anything I might be missing that I need to do differently here?
1) NTFS, 23GB
2) Linux Swap, 1GB
3) Linux EXT2, 5GB
