Jun 15, 2004 #1 D dfarrales n00b Joined Jun 7, 2004 Messages 41 i'm stuck in safe mode on my lappy.... the run command is gone from the start menu. how else can i switch back over? thanks
Jun 15, 2004 #2 J j4zzee Limp Gawd Joined Mar 6, 2004 Messages 290 If you are continually booting into safe mode something is probably wrong... Unless you hit the safe mode option with msconfig. manually remove the /safemode:<option> switch in your boot.ini file
