Ping the broadcast address of the local LAN and then check the arp cache. Problem solved.
For example:
3560# ping 192.168.0.255
3560# show arp
**Edit**
Or you can do what the post above mine illustrates.
Looks like this and the above are only working on the native VLAN. Those addresses show fine but the other VLANs dont. Any ways of peeking into those?
Turn on SPAN? I hadn't noticed there were multiple VLANS in play when I posted. If that's the case, set up a management IP on each one and repeat the steps listed above. If the VLANs are transient and you have no way to interact, you may just have to sit down at separate terminals or routers within those VLANs and ping the broadcast and view the arp cache.
I will look into this thanks.
One other question, using your method and assuming the network was flat, would that (pinging the broadcast address) fill the mac table with all macs/ips on the entire segment, or only on that particular switch?
All hosts in the subnet should reply to the broadcast ping and populate the arp cache with their MAC addresses.
