Sorry for my limited knowlege on this but can someone guide me through getting into it?
I recently purchased a used Linksys SRW2024P 24-Port 10/100/100 + 2-port Gigabit Switch with WebView and Power over Ethernet off ebay. I got it relatively inexpensive. It didn't come with any documents.
I have found a couple documents on it. I have found the SRW-US_v10_UG_A-Web.pfd. It stated to Telnet or HyperTerminal into it. I am not sure if I have the correct console cable (RJ45-DB9 console cable). The console port is a male DB9.
I have tried to telnet via Putty which it could not connect to. I would get the following message from Putty: Network error: Connection timed out.
(set static ip on Laptop to 192.168.1.253 and tried to telnet to 192.168.1.254)
I have a feeling that the router may not have been set back to default so my only hope may be to console but again i do not think i have the correct console cable.
Thanks
Thanks
