Diablo2K
- Aug 10, 2000
Title says it all. Tomorrow I am getting a Wii U and was wanting to get either a SD Card or a Flash Drive to expand the memory. Which would be better to get?
I would pay extra for a better quality one, like a Class 10 durable. You don't want it dieing on you.
OK, I got a PNY SD Card Class 10.
I have a External 2.5" 500gb Hard Drive laying around doing nothing, can it be used to expand memory?
SD Card, never go wrong with that..... All your saves can go on these and it can be moved easily. Its a life saver if you have ANY kind of trouble.
The flash drive is for when you start running out of room
Personally I use one of those external hdds that the USB from the Wii u can power. You're welcome to get the ones with a power brick, I've never used one of those personally but my old school 250gb does the trick.
