Wesley1357
- Jul 4, 2005
do u guys remember when in dos you could fix a damaged harddrive by using chkdsk to create files that would ocupied harddrive damaged areas and the result was damaged areas would be ocupied then you would lose those areas, and have less disc space, but drive could be used as normal showing up only the good undamaged areas. can this be done on windows? all i get are options to "repair" damaged areas, i don't want to repair them just put them aside... anyone can help?
