I just bought two of these fans to put them on the CPU heatsinks. I already had the 1850rpm versions which had a 3-pin connector I could use to connect them to the motherboard. The 3000rpm however have a bizarre type of connector: the red and black wires have a 4pin molex connector at the end to be connected to the PSU while the yellow wire just by itself has a 3pin connector to be connected to the motherboard.
My main question: with such configuration, can the system still control the fan speed according to the need?
Or, to have the fan speed being controlled by the system, do I have to move the red and black wires to the 3pin connector which plug into the motherboard? Is there a problem with connecting all three wires to the motherboard?
