I was going to get MUSHKIN 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory
Capacity 1GB (2 x 512MB)
Speed DDR 400 (PC 3200)
Cas Latency 2
Timing 2-2-2
ECC No
Registered/Unbuffered Unbuffered
Heat Spreader Yes
http://www2.newegg.com/Product/Product.asp?Item=N82E16820146355
for 204.55
But I saw this
GeIL Ultra 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory
Tech Spec
Capacity 2GB (2 x 1GB)
Cas Latency 3
Timing 3-4-4-8
ECC No
Heat Spreader Yes
http://www2.newegg.com/Product/Product.asp?Item=N82E16820144322
for $194.49
Question is will my ram be a bottleneck for my system if I go with the crapy Cas Latency 2GB? (see sig for system sepcs) I dont plan on do much OCing with the 2GB
I should just go with the 2GB and I wont notice any issues rigth? its a hell of a price
Whats faster 2GB with high Cas 3-4-4, or 1GB or 2-2-2
I want to be able to run Battlefield 2 at full specs.
Cas Latency 2
Timing 2-2-2
ECC No
Heat Spreader Yes
for 204.55
But I saw this
Tech Spec
Cas Latency 3
Timing 3-4-4-8
ECC No
Heat Spreader Yes
for $194.49
