GeForce RTX 2080 SUPER Launch Review Roundup
Discussion in 'HardForum Tech News' started by Schro, Jul 23, 2019.
  1. MavericK
    MavericK Zero Cool
    28,924
    Sep 2, 2004
    I'm not sure what people were expecting with this card. I guess it could have been 5% faster or so to make it more in line with the other Super cards, but it was never going to compete with the 2080 Ti.
    Armenius likes this.
  2. Snowdog
    Snowdog [H]ardForum Junkie
    9,347
    Apr 22, 2006
    No gimping. Where did you think the performance would come from? The other Super cards got a nice boost in Core count something like 10-15% more cores, This one only got something like 5% more cores because that is the limit of Chip, every single core is enabled here. There is nothing else to extract from this chip.
  3. clockdogg
    clockdogg Gawd
    911
    Dec 12, 2007
    Nothing, except more revenue...
  4. Nightfire
    Nightfire [H]ard|Gawd
    1,772
    Sep 7, 2017
    Put it this way: The RTX 2060s beats the 1080 with the same margins as the RTX 2080s does against the 1080ti.
    The 2060s launched at $400 vs $500 of its older sibling while the 2080s launched at the same price.
    Nothing Super about that.
    Absalom likes this.
  5. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,388
    Apr 9, 2012
    looking at the benches this isn't very super.
    RamboZombie and Jim Kim like this.
  6. MavericK
    MavericK Zero Cool
    28,924
    Sep 2, 2004
    I'm not sure saying the 1080 launched at $500 is really accurate - most of them were in the $700 range.
    But otherwise I get your point.
    Nightfire and AlphaQup like this.
  7. Gideon
    Gideon 2[H]4U
    2,298
    Apr 13, 2006
    Well I don't think 2080 Subpar edition sells as well.
    N4CR and Master_shake_ like this.
  8. Rvenger
    Rvenger [H]ard|Gawd
    1,768
    Sep 12, 2012
    Wouldn't a very modest overclock cover the deficit on the Regular 2080? So basically we are looking at a 2080 SSC with a tweak on the memory?
    Mav451 likes this.
  9. AlphaQup
    AlphaQup Limp Gawd
    300
    Oct 27, 2014
    My low (in the EVGA lineup) 1080 SC was $680 a couple weeks after launch, with the FTW and the likes going for $700+. $500 certainly isn't accurate initially, it took quite some time (1080Ti launch) for them to finally settle down to 500 or so if I remember correctly.
  10. Krenum
    Krenum [H]ardForum Junkie
    15,555
    Apr 29, 2005
    Super unimpressed.
    Especially for a $700 dollar price tag.
  11. Jim Kim
    Jim Kim 2[H]4U
    3,500
    May 24, 2012
    not super in any way, almost anti-super
  12. ManofGod
    ManofGod [H]ardForum Junkie
    10,885
    Oct 4, 2007
    Yeah but, the crazy thing is, at least in store, Best Buy is still selling the exact same cards that I could have bought last September from them. No Supers and no 5700's in stock, no surprise.
  13. misterbobby
    misterbobby 2[H]4U
    3,807
    Mar 18, 2014
    What the hell is wrong with the 2080 TI? It has over 40% more cores than the 2080 super yet even at 4K it's on average only about 16% to 18% faster.
    Ranger101 likes this.
  14. Mav451
    Mav451 [H]ardness Supreme
    4,528
    Jul 23, 2004
    That's actually a good question - is there a bottleneck we're not aware of?
    N4CR likes this.
  15. Snowdog
    9,347
    Apr 22, 2006
    Boost clock. It's above 1800 on the 2080 Super and below 1600 on the 2080Ti.
    Nightfire likes this.
  16. defaultluser
    defaultluser [H]ardForum Junkie
    12,541
    Jan 14, 2006
    Nah, it has way lower boost clock - likely to keep power in check, and also to keep costs down on VRMs.
    If it boosted as high as the 2080 Super, it would be 40% faster out of the box, but probably use closer to 400w.. So you have to do that manually.
    See here, where this massively factory overclocked model gets just 10% higher performance by adding 40w to the TDP limit, and much more efficient VRMs
    https://www.techpowerup.com/review/asus-geforce-rtx-2080-ti-matrix/27.html
    Adds 30w to power limit:
    And all you get is 10% higher performance at 300w. Getting the other 10% would require you to go to almost 350-400w.
  17. misterbobby
    misterbobby 2[H]4U
    3,807
    Mar 18, 2014
    No that is not it at all as you can go back and look at the 2080 TI reviews and see that most of them have an average boost clock in the 1800s and some of the aftermarket cards are in the 1900s. I'm even going back and looking at overclocked reviews from techpowerup and most of the 2080 TI cards overclock higher than the 2080 Super Cards. even with over clock though the difference is still well below 20% so something just doesn't add up as the 2080 TI just does not scale worth a damn.
  18. Snowdog
    9,347
    Apr 22, 2006
    It could be utilization/overhead, eventually even embarrassingly parallel loads start to suffer from overhead and difficulty trying to keep all those units occupied. There are 4352 cores after all.
  19. cageymaru
    cageymaru [H]ard as it Gets
    19,814
    Apr 10, 2003
    It is almost like NVIDIA went for more "features" like real-time ray tracing this generation than raw power.
    I suspect this is why reviewers keep joking that the regular RTX 2080 and RTX 2080 Super are refreshes of the GTX 1080 ti.
  20. Azrak
    Azrak Gawd
    830
    Oct 4, 2015
    This says it all. 2.5 years later, same price. 9% faster.
    But, RTX!
    Yeah. Hard pass.
  21. Stoly
    Stoly [H]ardness Supreme
    6,348
    Jul 26, 2005
    Well, if you were in the market for a RTX2080, you might as well get this one for a somewhat better value.
  22. DooKey
    DooKey [H]ardness Supreme
    8,102
    Apr 25, 2001
    If you aren't a high-end video card buyer then I see your point. However, there isn't any other way to go if you are a high-end video card buyer. The 2080S is a better buy than a Vega VII that just came out this year as well.
    GoldenTiger likes this.
  23. Stoly
    6,348
    Jul 26, 2005
    On 2nd thoughts I'd rather have a 10% price cut than 10% performance increase.
  24. Nightfire
    1,772
    Sep 7, 2017
    Meaning the value proposition of the 2080s over the 1080ti is even worse than that of the 2060s over the 1080.
    The 2060s also kept the same frame buffer size with more bandwidth compared to its older cousin.
  25. tungt88
    tungt88 [H]ard|Gawd
    1,997
    Jan 14, 2008
    Yes, I'm in the same boat with my "aging" GTX 1080, but nothing has really motivated me to go buy a replacement yet -- although a "cheapo" custom 5700XT (or 2070 Super) in late Aug/early Sep. might tide me over for the time being ...
  26. cambrian
    cambrian Gawd
    607
    Aug 5, 2004
    This GIF says it all about this card
    lostin3d, Mav451, seanreisk and 2 others like this.
  27. MangoSeed
    MangoSeed Limp Gawd
    506
    Oct 15, 2014
    For me the only card that would bring a meaningful performance upgrade over my 1080 is the 2080 Ti. That means it’s a hard pass on the whole 20 series.
    With cost per transistor still very high for 7nm it looks like nvidia will have to take a hit to margins for us to start seeing value again.
  28. vegeta535
    vegeta535 2[H]4U
    3,246
    Jul 19, 2013
    I'm sticking with my 1080ti til the probably the 4080ti comes out.
  29. MavericK
    MavericK Zero Cool
    28,924
    Sep 2, 2004
    I've seen reports that these can be overclocked a pretty decent amount, to the tune of another +5-8% performance or so. Brings it more in line with the other Super cards, if true.
  30. Master_Pain
    Master_Pain 2[H]4U
    3,898
    Apr 13, 2007
    I'm in the same boat. I am thinking about getting a 5700XT and then playing with sharpening to get decent framerates at 4k.
    tungt88 likes this.
  31. TheSlySyl
    TheSlySyl [H]Lite
    124
    May 30, 2018
    I just want something with more VRAM than my 1070 that actually looks worth spending money on.
    The wait continues...
  32. harmattan
    harmattan [H]ardness Supreme
    4,241
    Feb 11, 2008
    What I should have done, TBH. I went to a 2080 last October, then traded it in for a VII a few months back. With the exception of 1-2 situations where 16GB Vram comes in handy, both were definitve side grades from my 1080 ti I got ~2 years ago -- a total and complete waste of cash.
    The 5700 cards are really the only ones that have push the price/performance envelope in the past years at the top end.
  33. RamboZombie
    RamboZombie [H]Lite
    92
    Jul 11, 2018
    well, no one said cheaper - the refered to the bang-for-the-buck factor..
  34. exlink
    exlink [H]ardness Supreme
    4,374
    Dec 16, 2006
    After seeing the latest offerings from both Nvidia and AMD; my 1080 Ti continues to be one of the best, if not the best, hardware investments ever.
    2.5 years since I got it and it still holds its own against similarly priced cards out now.
    Maddness, GoodBoy, tungt88 and 2 others like this.
  35. Snowdog
    9,347
    Apr 22, 2006
    Same thing. If used had worse bang/buck no one would buy it. Used prices always have to fall to offer better value than new, so arguing that used has better value is pointless.
  36. Brokennails
    Brokennails [H]ard|Gawd
    1,978
    Apr 29, 2006
    For RTX, 2070 Super appears to be the best value..... But I guess for $200 more that extra 10fps of the 2080 super might be worth it to some. Sure as hell note though...
  37. Uvaman2
    Uvaman2 2[H]4U
    3,117
    Jan 4, 2016
    The Nvidia side- grade with useless features to keep pricing high got old, so I guess now its a mini bump in the stack to keep prices high strategy. And they pretty much re-jacked up the " middle" I think.
  38. Nightfire
    1,772
    Sep 7, 2017
    Giving a $700 card in 2019 with a 256 bit bus is simply insulting.
    This thing is so bandwidth starved:
    2060->2080: 50% more gpu 50% more perf.
    2060s->2080s: 50% more gpu 30% more perf.
    Just cranking up the GDDR6 clocks will not help. There is always a performance degradation when you hit a certain threshold despite nice-on-paper theoretical bandwidth. Latency could be crazy high as well. And, not least of all, the extra 4 gb of vram would have been nice.
  39. Ranulfo
    Ranulfo [H]ard|Gawd
    1,593
    Feb 9, 2006
    Much like charging $350 for a 2060 with 6gb ram and a 192bit bus.
  40. Stoly
    6,348
    Jul 26, 2005
    IF the RTX2080Super was bandwidth starved, increasing the bandwidth would help, duh!!! Nvidia is not as bandwidth limited as AMD since it started using all its compression technologies.
    Only in Mining did bandwidth make a huge difference, but gaming wise it doesn't affect much, if at all.
