GeForce GTX 1650 or Geforce 1050 ti ?
Discussion in 'Video Cards' started by ng4ever, Jun 1, 2019.
  1. ng4ever
    ng4ever [H]ard|Gawd
    1,426
    Feb 18, 2016
    Which one should I get for maybe light gaming at 2K and mainly Netflix and streaming tv shows + movies onto a tv or projector?
  2. Colonel_Blimp
    Colonel_Blimp n00b
    55
    Dec 30, 2017
    Neither yet, wait for Navi and decide then.
    1050ti too expensive for the performance it delivers so the choice should be 1650 or Navi
    IdiotInCharge and ng4ever like this.
  3. ng4ever
    ng4ever [H]ard|Gawd
    1,426
    Feb 18, 2016
    Thank you.
  4. Chimpee
    Chimpee [H]ard|Gawd
    1,458
    Jul 6, 2015
    You are better off picking up a RX 570 for almost the same price of a GTX 1650, or RX 580 when it sometime goes under 200 bucks.
    ng4ever likes this.
  5. Chimpee
    Chimpee [H]ard|Gawd
    1,458
    Jul 6, 2015
    The only time I probably will recommend a GTX 1650 is if you don't want to use additional power connector, then I can see why people would take the GTX 1650 as you can power it thru the PCIE slot alone. It is the most powerful card at 75 watts.
    defaultluser and IdiotInCharge like this.
  6. Criticalhitkoala
    Criticalhitkoala [H]ard|Gawd
    1,699
    Apr 17, 2015
    You can easily get 1050s for sub $100 used. I would do that tbh if you just want to use pcie power. If you can put power to it the 570 is a lot better.
  7. GoldenTiger
    GoldenTiger [H]ard as it Gets
    18,877
    Dec 2, 2004
    You can get gtx 970 cards for $100 used. I've seen 8gb RX 570 ones new on hot deals for $125 recently.
    Chimpee and Criticalhitkoala like this.
  8. TheFlayedMan
    TheFlayedMan Limp Gawd
    406
    May 29, 2015
    Used 1050 ti's are also cheap
