I have a GeForce 210 low profile card same as below:
http://www.newegg.com/product/product.aspx?Item=N82E16814143208
it is installed next to a tv tuner card. I used to experience image cutting in/out (TV would go blank for a second and resume, showing the current input) every half hour or so. Now I notice that it happens about once every minute. It happens even in text mode (Windows boot menu). Does anyone had similar experience? How should I deal with it?
Could it be due to overheat? There isn't much space inside the PC but the PC itself has enough gaps all around. How do I check the temperature of the GPU?
