Gauging interest for motherboard trays for benchers
Spotswood
Removable side panels are now available:
Panels come with either two 120 or 140mm fan hole cutouts in each side/short panel, and optionally with three 120 or 140mm fan hole cutouts in the front/long panel. The back of the case remains open.
Spotswood
A new open frame (skeleton) ATX size tray is now available that can accommodate a standard size ATX motherboard, PSU and a single 3.5-inch hard drive or SSD storage device.
Spotswood
A couple of small custom jobs: an ATX top with fans holes and a custom station made from two small tech trays.
TheGeekFreek
These things just keep gettin sexier Spots..
You do some freakin fantastic work.. Miss the roar of my old BTC quad stack made of these..
Spotswood
Finally! A simple, inexpensive 4p/SWTX size tray (made entirely from 15mm square extrusions) that can be stacked.
The tray has room for one SSD/HD.
Spotswood
Added an inexpensive tray for those mining with multiple GPUs connected via ribbon cables:
The GPU support beam is included with this tray.
Spotswood
All of the lighter-weight trays (15mm extrusions) are now stackable with an optional set of posts for $5.
Here’a a pic of two stacked BTC/LTC “mining trays”:
Spotswood
Mining trays can now be purchased with extra tall posts so two trays can be stacked at the perfect height in order to be cooled by a standard 20-inch box fan.
m33pm33p
[H]ard|DCer of the Month - August 2013
Spots, would the new box fan mounts hold a SWTX board? Or are they strictly for ATX and below?
This might be my Christmas present to myself.
Spotswood
Yes, of course. These t-slot extrusions are very modular, so it very easy to attach a do-dad/thingy/fan mount where ever you want 'em. :D
Spotswood
For the next few weeks, I will only be offering the mining trays with painted aluminum sheeting for $95:
Spotswood
Plastic end caps are a new option for the trays made from the smaller (15mm) extrusions:
$.55 each.
Spotswood
The mining trays (actually, all of the trays built from 15mm square extrusions) now ship with plastic tabs to fasten the PSUs directly to the extrusion:
