Gauging interest for motherboard trays for benchers
jebo_4jc
[H]ard|DCer of the Month - April 2011
Omg. That's $1000 in heatsinks.
Insanely sweet setup.
Patriot
[H]ard|DCer of the Month - March 2011/June 2013/De
"Special Order" at Provantage means "you'll be waiting 2 weeks at the very minimum for this to arrive, and we might never get it in stock at all"
tis often true...but considering this is the man who bought the sinks... is saving 360 on hs worth the wait?
Spotswood
I'm pleased to announce a new option that will allow you to securely mount hard drives to almost anywhere on the tray. :) $5 for one set.
More info here.
jebo_4jc
I like it. I want one. My hard drive is the loudest component in my system
jfb9301
[H]ard DCOTM February 2016
Why would you hang the ODD on the outside?
Wouldn't the HDD mount flat on the inside of the area, hang the ODD above the HDD and done, and it all fits inside the case
Spotswood
The ODD is too wide to be mounted over the HDD area.
TheGeekFreek
I know this is really late.. But today is the first time Ive had all 4 cases in 1 place
flogge
Are you currently making and selling cases, Spotswood? I may be interested in a case with the video card rack and some water cooling provisions.
flogge
Excellent. I'm off work next week so after Christmas I'll spend some time going back through this thread and figure out what I need.
Spotswood
Stacks of trays are now fastened together with hidden threaded dowels.
And are now shipped with heavy duty stainless steel fan mounting tabs.
I remember reading this thread when it started, I am very happy for you that it has blossomed into a reality for you!
Btw, where are you located?
Wicked, I grew up in Milford, NH, although I am currently in Atlanta.
I am looking to start a test bench/ folding bench and I definitely want to get with you and see what we can do.
Spotswood
The temperature is supposed to go down into single digits this weekend. Maybe you should come up to help in the shop. hehe
Send me a PM of what you have in mind.
FrEaKy
[H] Movie and TV Show Review Guy
These trays have evolved into full-blown tech stations.
More info here.
Now this is wicked brosif...... I will be getting in touch with you very soon cause I need one for my 1366 incoming board (thank you UntitledOne).
Untitledone
[H]ard|DCer of the Month - April 2012
Do not just thank me :) I am just the leg man. The board was originally Patriot's and I just did the work of RMA'ing it.
Spotswood
New design with 6 posts provides a built-in location for mounting a hard drive via grommets.
Or the HD can safely rest on the soft grommets.
These now have cast aluminum 90-degree brackets to holdup the expansion card support beam.
Lastly, added another upgrade, which is stainless steel tabs are now used to mount 3 fans and a PSU.
More pics and info here.
Spotswood
There's been some confusion as to how to use the expansion card beam/clamp. The card is sandwiched between the two halves.
Spotswood
A lower tier for the 4p/SWTX size trays is now available.
You can fit one or two 120x4 radiators across the width of the tier and its tall enough for three 5.25-inch bay devices.
Spotswood
A new smaller size ATX tray is soon to be available that can accommodate a standard size ATX motherboard, PSU and a single SSD storage device.
This is a smaller bare-bones version of the other trays (not stackable; no expansion card support) and is therefore priced accordingly.
Some more info here.
