Gateway startup problem
btb103
We've got an old gateway computer (at least 5 years) that we haven't used in awhile due to getting a couple new ones. My sister wants one in her room so I put in a new hard drive (the old one was slow and faulty) and figured it would run as normal. When I try to start it up I get BIOS beeps of one long tone then two short ones in succession. I don't have the manual and don't know where I can look up what this means. Nothing shows up on the screen and the computer just runs after the beeps. Thanks!
Sounds like bad memory. Change out memory, then reset CMOS, try to boot again and see if it POST.
I want to say that I had a Compaq do the same thing to me a while back. I think I cannibalized the computer and junked it before I figured out exactly what it was.
I'm guessing that you don't have a display on your monitor at all, your hard drive isn't spinning up, and all of your fans are working?
