Zerokenohki
- Jan 23, 2008
Thank you very much for doing this Deeghan! This will help with my purchase!
Has everyone up until this point only received FHD2400's manufactured in September 2007? I picked up one yesterday with the date of February 2008.
(Sorry for the unsharp image, but a better one would require me unscrewing the display from the stand and all that other nonsense...)
From what I could tell, no one has reported the 2/08 version yet. I've left the brightness at a full 100 and have taken pictures of its open box state. I'll continue to take pictures every 24h (from the same position using the same camera settings) to see if the backlight problem really worsens when brightness is left at its full magnitude.
There's some back light bleeding, but all TN panels do this anyway to a reasonable point.
9-15 hours of use:
Backlight Bleed:
~48 hours of use:
Backlight Bleed:
I purchased this monitor a couple of days and overall have been pretty impressed. Just a quick question.
Is the EZTune Software beneficial? I'm running a Mac though (isn't the irony great?), so I'd have to boot into XP I suppose.
I was wondering the same thing. I was looking for a way to direct the audio from HDMI out to some speakers without having to go through my computer first.hey. dus anyone know what connection you use to connect the speaker bar? it looks like an s-video plug. but s-video is... video. ha. wud i be able to find an adapter to make that RCA ports?
so what is the best as far as connection for the 360?
if i had an elite i guess it would be hdmi but i just have the reg. xbox 360.
Currently running 360 on component (looks shitty)
VGA?
DVI?
Help.....
Absolutely incredible screen.
However, I'm on my second one from Best Buy. The first had a stuck red pixel on the left. The one I am staring at now has a blue pixel on the right.
I'll be going back and forth until I get a screen with no dead/stuck pixels.
Just went to another Best Buy and had Geek Squad open up the box to check for stuck pixels. Amazing luck, the first one I got has no dead or stuck pixels whatsoever.
Unfortunately, Joke Squad must have put a fingerprint on the screen while they were taking it out of the box. Used a clean t-shirt to wipe it off. Being the paranoid individual that I am, however, I am afraid that I might have taken off some of the glossy layer (if you had ever wiped a glossy screen with a paper towel, you'll notice that the area you've wiped will be smoother than normal).
How do you guys clean glossy screens?
