I keep mine at 100- turning it down dosent really reduce the bleeding and i like it bright
I was so interested in this monitor until I read this thread just like I was interested in that FP2485W before I read THAT thread, just like I was interested in the XHD3000 before I read that thread too.
Do we know if this monitor is true 8-bit ?
The biggest problem for me is not the redness on the sides-i hardly ever see that. Its the top 1" of the screen. If im at eye level with the "gateway" lettering, the colors in that area start to "inverse out" when i get within about 1.75 feet, and even if im perfectly centered
I'm an avid reader of the forum but a newbie poster. so hello to all. I'm on the market for a new monitor and this monitor caught my eye until i read about all the BLB owners are having.
Hopefully some one can answer a few questions for me.
Does any one know if a new revision is going to come out for this monitor to correct the current issues? Is gateway going to continue to put problematic monitors on the market? How does the BLB affect console gamers?
yeah the monitor does have prblems with BLB, but not to the extent where i woud call the monitor problematic- its an exellent monitor
I have a few minor problems with this monitor. Can others confirm?
1. Switching from HDMI to DVI makes the DVI input colors go crazy. I think the input mode is getting switched out of RGB.
Overly picky? I don't think so...
My first FHD2400 had no BLB at all the first few days... When it started to appear, I was ok with it... But in about a week and a half, it was so bad that the top 5 inches of the screen was washed out... I was playing a first person shooter and you couldn't see any of heads-up-display gauges due to the BLB (they were completely washed out).
After the BLB got really bad, I had 3 friends over to play Rock Band and they all said that it was absolutely the worst monitor they had ever seen. On the day I got it, they came over also, and they said it was the best looking one they had seen. Go figure.
This is a serious issue. And after speaking with Gateway, and them telling me that they have not had any complaints about this, I don't think I will ever buy another product of theirs again, because they obviously don't take customer complaints seriously, because we know that people on here have called, and I am sure countless others...
Ok, so I've had this monitor for 2 months now. I consider myself pretty picky when it comes to how things look and I was constantly noticing the bleed while gaming and it really annoyed the crap out of me. The bleeding on the left/right side is tolerable, but the bleeding at the top inch of the screen really bugged me because it makes everything darker and changes the colors.
The response time on this lcd is good. This monitor is great for windows applications, the bleed wasn't noticeable unless I was gaming, watching dark movies, or had a black desktop wallpaper.
Recently I figured out a fix for the backlite bleeding for gaming and I thought I would share it with you.
I tried turning down the brightness really low like many suggested, but games just seemed way too dark and the bleeding was still very noticeable. I have an ATI video card so I don't know if the darkness was from that or what. Anyhow, what I did was I setup a few different color "profiles" in the ati catalyst control panel which are all hotkeyed. The key is increasing the contrast and brightness in your video cards software control panel. I increased the contrast to 150 and the brightness between 15-40. I run the lcd at 15 brightness, 40 contrast.
I can now game without constantly noticing the bleed. The only annoying thing is having to hit the various hotkeys for the different color profiles. It's not a perfect fix as colors may not look as rich, but it's a fine compromise imo, games still look great and I don't notice the bleed anymore so I can focus on having fun while playing my games again.
Brightness=0, all inputs. That's still pretty bright on undamaged panels. I have posted many pictures at 5 out of 100, and 0 isn't much dimmer than that. As near as we can tell, anything higher will slowly develop more BLB. Once ya got it, ya got it forever, unless you turn in the panel in for excessive BLB.
Just purchased one of these and I'd have my own experience to toss in as well as some clarification:
~ did the brightness to zero tip and it really does muddy the colors a bit too much for me. The reason for this is that the image is already muddy and dark, compared to my old CRT, on the component, composite or vga inputs from xbox or television.
While the tip of mixing and matching contrast/brightness settings on the video card makes some sense, it's unfortunately not possible for the TV/XBOX inputs at such a refined level.
~ the backlight bleeding is pronounced. Day one and I have a lot more than I've seen in pictures here, but it isn't an amazingly bad amount. It's as much as I've had on most of the LCDs I've owned.
What I'm curious about is the fidelity of the monitor. I hear people raving about how great XBOX360 looks on it and I'm just not getting anywhere near the same quality out of the VGA input that I do when plugging into my CRT monitor. I will try an HDMI cable but the screenshots I've seen comparing the HDMI / VGA / component cables all look basically the same to me. It seems a bit reaching to talk about shadow detail increase when the rest of the image is dreary and blotchy.
Perhaps this is a calibration issue? I'm using the "game" preset and tweaked the colors and settings as best as I can, but they're just generally very contrasty (especially with brightness down to zero) with the blacks crushing together.
I've tested this with gears of war which is a contrasty game and blue dragon / katamari which are both very vibrant. They both become very dull and contrasty.
The oddest part about it is that the computer looks fine through VGA, which is why I bought the monitor - it really is the best 24" monitor i've seen color/brightness and saturationwise. I'm using it for apps so not too concerned about the mediocre television, upsampling or whatever this thing must have given its price point... but of course it has this stuff and I'm just boggled at how people can rave about how great it looks with that stuff.
Can someone clue me in? I've seen too many rave reviews, specifically for xbox, and I'm just not seeing it. Gateway even shows an xbox on their page for the monitor so i'd assume it'd look "great." But is this "great for a low-end LCD tv technology"? Because I have a $50 20" CRT monitor that looks absolutely flawless for x360 with the VGA cable...
In the end, I wish they'd just chop the price down even more and produce this as a computer monitor only. Of course I'm still considering that I'm doing something wrong (I can rule out defective unit because the VGA input from the computer looks fine, right?) but it really feels like all of the inputs are tacked on with cheap-o conversion going on in the guts. That rhetoric should be enough to convey how little I know about how these things work
You should try to adjust the gamma settings in the xbox console. If I recall correctly, there are three such settings, although I think the intermediate one is useless. That normally does the trick in terms of fixing the VGA "wash-out" problem.
Yeah I had the same problem until i put it on the maximum setting, then VGA looked great.
Ugh - defective monitor then? Or perhaps I'm being too fussy about what "great" means. I will try and grab some photos tonight.
ive decided that i cant stand the backlight bleed any more and i want to replace my pannel now
But will best buy just say OK and give me a new monitor if i say "it has backlight bleeding"? I dont even have a warrenty or anything
well, these screenshots are very close to mine
http://www.hardforum.com/showpost.php?p=1031712145&postcount=391
The blown out, blurry jaggedness of the mini-track in the upper left, with the lights.
how cod4 looks very splotchy and contrasty...
the dullness of the images in general...
is this what people considers "great"? Never mind that the original poster's screen might not be represented in the photos, but pretend that's what my screen looks like
