Gaming PC for around 5000 euros;;
Discussion in 'Computers & Gadgets' started by PANOS, Jan 4, 2019.
  1. PANOS
    PANOS n00b
    11
    Jan 2, 2019
    Hi one my friend was to build one new gaming pc for games
    the budget which he can give is 5000 euros maxinum,
    can you help me with the build of 5000 euros on PCPartpicker choices;;
  2. showard
    showard n00b
    6
    Jan 10, 2019
    That's a crazy high budget! With that amount of money you don't have to build. Just go online and buy the highest price gaming PC you can find. Done.
    kirbyrj and sabrewolf732 like this.
  3. defaultluser
    defaultluser I B Smart
    12,142
    Jan 14, 2006
    Yeah, that's basically unlimited.
    What games was he looking to play? Or was this intended to be a workstation as well?
    You don't need to spend more than $3000 if all you want to do is game.
  4. sabrewolf732
    sabrewolf732 2[H]4U
    3,790
    Dec 6, 2004
    get a 2080ti 9900k 32GB memory sick monitor set up and invest the rest into something that won't lose 90% of it's value in a year.
    horrorshow likes this.
  5. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    Is the PC strictly for gaming?
    What size monitor does he want?
  6. BlueLineSwinger
    BlueLineSwinger Gawd
    586
    Dec 1, 2011
    If you're not even going to try to do some research and put together a build and instead expect others to do all the work for you here's my recommendation:
    Go buy a preassembled system from Alienware or some other similar gaming-focused/boutique company.
    cyclone3d and silk186 like this.
  7. legcramp
    legcramp [H]ardForum Junkie
    10,773
    Aug 16, 2004
