Wiseguy2001
- Nov 28, 2001
Hi, I'm playing more FPS's and I could do with more directional sound. My existing system is Audio Engine A2's with onboard (yes, I'm a little a shamed) Realtek ALC892.
The number #1 headphones on my list are Sennheiser PC320's, which do seem to be pretty good value, compared to it's more expensive PC360 cousin in some reviews. Plus they're only £70.
I also think it's time to buy a proper soundcard. I haven't brought a soundcard in over a decade! The last one I brought was a Creative SB live platinum.. It seems these days, there's only two manufacturers in town, Asus and Creative. Ironically it seems that it is Asus, who's drivers suck. I'm thinking of getting an SB-Z which should fit my needs and has a built-in headphone amp, but the above are only rated at 32ohm's, so not exactly power hungry.
I'm not deadset on the budget and can spend more, but I am tight.
What do you think of my choices yeh, nah?
