Gaming laptops...
snowhawk
Hey guys! I am looking at gaming laptops. I came across this one, the Legion 5 by Lenovo. I hear the wifi card is bad and needs to be replaced with an Intel one.
https://www.microcenter.com/product...ming-laptop-computer-platinum-collection-blue
Are there any other laptops that come close to this laptop? I figure I can always upgrade the wifi card.
MSI/Acer/Gigabyte/Auss/HP/Razer ... do any of these compare?
I've been doing a lot of research, and reading reviews. Trying to get all my info together before I buy a laptop in the coming weeks.
Can I do better than this laptop I listed? Thank for your thoughts!
Jinto
Legion 5 is solid. Wifi is definitely bad though, I have the same Realtek card in my ThinkBook and plan to swap it out with the Intel as well.
Best buy has Legion 7 Slim on sale for the same price. It is a good bit more premium and lighter but sacrifices a bit of wattage on the 3060. Good deal if you want your gaming laptop to also be portable.
jarablue
Everything now is mostly shitty max q video cards. Where is the list of higher performing max p laptops?
Why do they not state this up front as a major selling point? I do not want to buy any laptop with a gimped max q vid card.
Aurelius
As I recall, NVIDIA more or less ditched that system; now it's more up to the vendors (and curious buyers) to disclose what the performance is. Yes, it's confusing, and yes, it can mean that a laptop with an RTX 3070 might perform faster than one with a 3080 if the thermals are different.
Also, a laptop with the equivalent of Max-Q isn't "gimped;" it just means that the emphasis may be on portability or longevity. I can certainly understand wanting the best-performing laptop for the money; just know that frame rates aren't the only deciding factor in some laptop purchases.
ThatITGuy
I got a high end gaming laptop just before the pandemic. It actually has a mobile 2080 (not Max Q). I have enjoyed it and used it for a long time as a desktop, while i picked up parts for a new desktop build. My problem with it is that it gets hot, then gets loud. The chance for portability is nice, but I have found that I do not move it around as much due to the bulk (both the machine and the power brick), the heat, and the noise making it more awkward to use.
harmattan
Ultra confusing. It can also mean a mobile RTX 3070 performs like a mobile RTX 3060 (which performs like a desktop 3050 ti) because of the power envelope the vendor decided on for their laptop. Also, nV has once again reverted to using cut-down chips with the same number designations as their desktop counterparts e.g. a mobile 3080 has significantly less CUDA and tensor cores than a desktop 3080.
Max-Q branding wasn't perfect, but you generally knew what you were getting: a power-reduced version of the chip meant for portability.
