Syranthian
- Apr 18, 2011
For those who've tried both, is it really difficult gaming on larger (27"+) displays? Or do you prefer it to triple-monitor setups?
I've been wanting to jump into Eyefinity, looking at 3x24" monitors (5760x1200 if possible) primarily for gaming with light non-graphics-related office work. Several reviews suggest triple-monitor just doesn't beat one monster monitor. Others still say 16x10 is a dying format best avoided, though I have an LCD TV for my console gaming and movie needs.
Sadly in Japan Dell is far cheaper than HP, so the ZR24ws are a bit pricey. Any suggestions on a good setup? Am also considering buying a large main display for gaming and going PLP, but matching the side monitors seems tricky. Looking to avoid TN panels and go with an IPS that isn't too bad with input lag.
Prices in Japan (converted to USD):
Dell U2311: $300 (x3 = by far cheapest option, but 1920x1080...)
Dell U2410: $500
ZR24W: $580 (my current choice, but expensive)
Dell U2710: $615
Dell U3010: $1400 (input lag?)
ZR30w: $2000 (!)
Budget is ~$1700, less if I can help it (U2311s are so inexpensive they tempt me despite the smaller resolution and real estate). Unfortunately retailers in Japan do not stock either HP or Dell so I CANNOT preview these before buying, which scares me because of AG coating nightmares mentioned all over the place.
Thank you kindly for any advice or accounts of personal usage...
Dell U2410: $500
Dell U2710: $615
ZR30w: $2000 (!)
