The idea is to have a quick and easy docking solution for laptops that have no centralized docking feature with added eGPU support, extra laptop CPU cooling and hidden cabling. All a gamer may need in one flat package.
EGPU Case assembly (50x20x7cm):
Dock assembly:
Bolt the eGPU and the cooler plate to the base and add the sides. Then you slide the laptop in, close the sides and you are good for gaming. Same for removal, just open the sides, slide the laptop out and you are ready to move.
It should work for all laptops in any size and configuration because the plugs are held in place by consoles, can grab onto plugs of various sizes and hold them firmly in place. Plus it allows movement on all three axis during setup.
Z axis:
Y axis:
X Axis:
Continue with more pictures.
Dock assembly:
Z axis:
Y axis:
X Axis:
