- Aug 20, 2006
I still think curved displays like the Edge are gimmicky, but I do like the sound of that battery. The Note 6 is also expected to be IP68 water resistant and possibly include an iris scanner.
The other interesting tidbit in this leak is the battery size of the Note 6. The source doesn’t exactly know the battery capacity but suggests a 4,000 mAh battery might power the device. With a larger body, it wouldn’t exactly be hard to fit in a 4,000 mAh battery inside the Note 6, especially if Samsung makes the device thicker than its predecessor (a move that helped the company fit the large batteries inside the Galaxy S7 and Galaxy S7 edge).
