I have a GA-X58A-UD3R motherboard with a Corsair 650W power supply, both are new.
what happens, is i turn it on, and the power cycles infinitely.
if i take out the 8 pin power, then it works (but i turn it off quick, to avoid damage)is this due to a defective power supply, or more likely the motherboard? I dont want to send the wrong thing back!
The only other thing of note is that it was working for about a week since originally built, then i turned it off, when i turned it back on this started happening.
EDIT: i remembered i had another PSU, i tried it and it does the same thing.
EDIT: tried again outside of the case, same thing. I guess its back to the trusty old P6T!
