I currently use a Gigabyte UD5 motherboard paired with an AMD 8350 CPU and 32GB RAM for my ESXi 5.1 host. I have 2 VMs on it, Ubuntu Server 12.04 and Windows 7. I built a FreeNAS box using an old CPU and motherboard to experiment with, but it has become unstable (probably a bad motherboard). I would like to transfer the FreeNAS to a VM on my ESXi host.
The question is this: Do I have to buy another controller (like a M1015) to plug in the hard drives, or can I cheat and passthru the onboard SATA controller? Normally I would say it can't be done because the SATA controller drives the datastore drives, but the UD5 has a second independent SATA controller. If I put the datastore drives on the second SATA controller, is it possible to then passthru the main SATA controller to the FreeNAS VM? My ESXi boots from a USB key so I don't have to worry if the second SATA controller is bootable or not. The reason I don't want to use the second SATA controller for the FreeNAS VM is that it has only 2 ports.
I'm asking now because my datastores are on hard drives connected to the main SATA controller now and it's a pain to move them. I'll do it if it has any real chance of success, but if it won't work then I'll have to break down and buy a M1015.
Thanks in advance for any helpful advice!
