G604 Program button question
EagleWorks
Hello all ...
New to this forum.
I've had the G604 for some time, but really haven't taken time to program the buttons.
My questions have to do with programming the buttons for a certain applications.
I don't do gaming, but want a set of buttons for various application (or system control), say Firefox, YouTube, Quicken, Sketchup, Affinity Designer, and others.
For example, I might use Sketchup to do some 3D drawing.
I want to program some buttons for that application.
Then, say I want to switch to Quicken or some other application with its own set of buttons.
This means assigning the same buttons to some other command.
How do you set up the buttons to match the application?
Could someone point me to some tutorial or instructions on how to do this?
It seems to me that one would need to identify and set the application being used before assigning buttons.
I hope this is making some sense.
The instructions in Assignments say to drag a system control onto a target to assign it to this device.
What target? Does that mean one of the buttons? If so, then that button gets changed when you assign a command to that button.
Does that wipe out the system control?
I could go on about what I am trying to do.
I'll stop now and hope someone has a simple way to describe how to do this.
Thanks for listening.
Bob
The red circle is where you pick the profile, which can be an application or a game. Your mouse will automatically switch to the profile for that application when you're in it and use those button mapp;ings.
Hey! Thanks for getting back with me.
That is the direction I was heading after some research. I can't believer that Logitect doesn't have a manual that covers that in depth.
So, is it normal that I see Desktop:
m
That is the direction I was heading after some research. I can't believe that Logitech doesn't have a manual that covers this in depth.
So, is it normal that I see Desktop: Firefox, and/or the various applications that I have would be in this drop-down box?
And the application that I am setting up needs to be added and/or selected when I am assigning buttons to that app, right?
I do have one line item in the profile drop-down that I probably added at some time during deep confusion!
It is QW: Quicken. I would like to delete this line, but can't seem to figure out how to delete it.
I guess it could just stay there.
Finally, one more item for now.
On the Assignments tab or panel. There is a button call SYSTEM.
I'm assuming I need to have all my applications listed here?
Enough for now.
Thanks for listening and responding.
Have a great holiday season ...
Bob
