Hi All,
Got 2 PC's - trying to swap CPU's from one to the other.
My G3258 won't work in my Z87M Board, but the Intel i5 4760k, works in both boards.
RAM works in both boards (assuming I'm booting with the CPU which is working in both)
BIOS up to date on both boards.
BIOS reset on offending board (CMOS reset)
I've even booted into Windows and used the official Asus update for Windows which (appeared) to imply it worked differently.
No bent pins, can swap CPU's back and forth all day, the only common factor is the G3258 won't work in the older board.
Asus lists it as compatible.
http://support.asus.com/cpusupport/...=45&m=Z87M-PLUS&os=&hashedid=UjihzQKhBmQmiVsY
Found someone else with the same issue too.
http://www.progtown.com/topic1931584-asus-z87mplus-does-not-work-with-pentium-g3258.html
Anyone else seen this?
*Note:Before using the new Intel 4th Gen Core processors, we suggest that you first update the BIOS using USB BIOS flashback, or download the BIOS updater for new Intel 4th Gen Core Processors and then update the BIOS using it.
