G.Skill Trident Z Dual Channel not working on i9 and Z390
PzSniper
On 11th Jan after a week all pieces has arrived but ...got a big big problem... Hoping on your time and support, here's what happened.
i assembled my new pc, and here are the specs
INTEL CORE i9-9900K
ASUS ROG STRIX Z390-F GAMING
ASUS ROG STRIX RTX2070S A8G GAMING
PSU COOLER MASTER SILENT PRO GOLD 1000W
...but i can use ONLY 1 DIMM of my G.Skill Trident Z F4-3200C16Dm DDR4-3200MHz CL16-18-18-38 1.35V 16GB (2x8GB)
1 DIMM works B2 both of them if interchanged.
2 DIMM doesn't work in any combination b2 a2 or b1 a1...system start with MEM OK test, flash cpu red, flash yellow dimm led, reboot few times and then stop with 2 leds on solid yellow .
I dunno what to try after 5 hrs... already updated ASUS BIOS of ROG STRIX z390-F to the latest 1401 dated 11 Dec. 2019
ofc ram is listen on QVL for this mobo....
Please advice
sounds like one of the sticks is bad ( the one you cant get to work will have to be rma'd) but most people would just return both sticks to the merchant for exchange
was the first i thought BUT as its written i DID switched the DIMM using same B2 socked and BOTH worked, in single channel...so i think problem it's not the faulty stick
I misunderstood you first post...in that case it sounds like a bad motherboard ram slot. what does the manual say on the 2 solid yellow leds?
You could try reseating the CPU and making sure there are no bent CPU pins in the socket.
och didn't thought about that, i see 2 pins slightly misplaced (direction) now i'm f***.
Mobo is brand new but i doubt can request RMA for that..looks like i lost 200€...
Are u 100% sure could be that the culprit? Can't i try anything else??
You should be able to bend them back. Google bent motherboard cpu pins and watch a couple videos until your certain you know what your doing. Just take your time and youll be up and running in no time.
It's possible that it is, take a pic and post it here so we can see how bad they are bent. You might be able to bend them back with a pin or knife point.
