MazerRakham
- Feb 22, 2012
Recently built a new rig with an i5, p8p67 MB, and gskill ripjaws 8 gb 1600mhz memory (2 4gb sticks)
the system has stability issues (freezes on prime95 burning, and fails mem tests) but when I enable XMP, it seems to work fine.
I tried some corsar vengeance (same specs) and it worked just fine on default settings.
Why do i need to overclock the gskills? (XMP) will this effect my ability to overclock the cpu? is this bad for the board?
Thanks.
Thanks.
