Chaballaman
- Jun 26, 2001
wats the diff? they both run 2.4ghz, 1mb L2, 939..
while you're right, this is about the fx-53 and 4000+Zoio said:FX55 uses strained silicon
Captin Insano said:The A64 4000+ is not a crippled FX55 or even a FX55 that wouldnt do 2.6ghz and was a defect. It's not even in the same core family as the FX55. The only thing that the 4000+ shares that the FX55 has is 1mg L2 cache andf SOI.(eventually all A64 and FX and dual cores will be SOI) The FX55 even has more on die instructions added to it then anyother chip that AMD has out in the A64 and FX line. (rememer there are even 754 pin A64 chips that have a 1mg cache on the L2 but that doesnt make it related to the FX chip either) The 4000 is a A64 4000.Nothing more nothing less.
(cf)Eclipse said:yeah, i think he meant to say strained silicon, not SOI..
